thomashilton
Nov 08, 2017Aspirant
Can 10G LAN SFP+ port be used with a ASRock motherboard that has a 5Gb Ethernet port
Can the 10G LAN SPF port support normal ethernet at 5GB instead of NAS traffic. My computer has a 5GB Ethernet port.
- Nov 08, 2017
There is no cheap way for 10Gb :mansad:
You have either use some kind of adapter (picture), or use additional PC 10Gb Ethernet card with SFP connection.
thomashilton
I might try a Ubiquiti Networks ER-X-SFP-US Advanced Gigabit Router with PoE and SFP between them. Do you think this would work?
- PauLitaNov 08, 2017Luminary
Sure.
- thomashiltonNov 08, 2017Aspirant
Any suggestion on the best and most economical way to do this. I have never seen the pinout for a SFP+ connector?
Thanks
