GNK48
Sep 18, 2015Aspirant
Can a Nighthawk R7000 become a repeater to an Aircard 785 (canal 19)
Trying to setup a Nighthawk R7000 as Repeater behind an Aircard 785, I hit the following difficulties. The 4G Aircard uses channel 19, but the Nighthawk choice of channel is limited to range 1-13 (2...
- Sep 25, 2015
Dear TheEther, As I could not progress, and Windows 10 kept refusing the communication with the Nighthawk, I finally went to the Technical support, because the Windows diagnostic messages being in French, I thought this would be simpler.
Here is what Technical suport says:
"In your case, I inform you that the configuration you want is not possible, the Aircard does not have the function of WDS that is necessary to make the communication with the R7000. Also, the WDS function only works with WEP encryption (which limits the speed to 54mbps). Finally, the wifi Repeater function is being deleted on newer versions of firmware. "
So I assume this is the final reply is : a Nighthawk R7000 cannot become a repeater to an Aircard 785
Thank you again for your help.
GNK48
Sep 20, 2015Aspirant
Thank you again for your help. We are almost there.
After hitting the "Apply" button, the system starts updating the router with the new parameters, but the process aborts, claiming "insufficient time to handle the request".
Do you know where this timing authorization can be adjusted: the updating process is indeed quite slow, about 30 seconds, after the progress bar appears and starts filling...
Looking forward to your next input.
TheEther
Sep 20, 2015Guru
After you hit the Apply button, the R7000 should have switched to repeater mode. If you had also assigned it a new IP address, then your browser session to the R7000 will have been orphaned. This would eventually appear as a timeout on your browser. Try connecting to the R7000's new IP address.
- GNK48Sep 25, 2015Aspirant
