zsmehta
Aug 02, 2021Follower
Can i assign static IP to a printer
- microchip8Master
Static IP is set on the device itself. You're most likely asking for a Reserved IP on the router. If so, get the printer's MAC address and assign it an IP address
If you want to do that, the printer's control software is the usual way in.
