Auntsuewhite
Aug 08, 2023Follower
Can I have both 2.4G and 5G on this router?
Will this model allow me to use both the 2.4 and 5Ghz? All of my devices this far have run on 5, but I have purchased a water monitor that requires 2.4. Can I have both run simultaneously?
- microchip8MasterWhich model? You don't say!
Most new models support both 2.4 and 5 GHz bands. - michaelkenwardGuru - Experienced User
Auntsuewhite wrote:
Will this model allow me to use both the 2.4 and 5Ghz?I have never seen a Netgear router that does not support both. (Some even support 6GHz as well.)
But many don't have, or hide, separate SSIDs for 2.4 and 5Ghz.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the section in the manual Specify Basic WiFi Settings.
..I have purchased a water monitor that requires 2.4. Can I have both run simultaneously?Turn it on and follow the instructions to connect it to the wifi. It may just work.
Come back if you have problems.
