StanH
May 12, 2021Tutor
Can I remove NETGEAR USB Control Center?
Should I remove "NETGEAR USB Control Center" 11/21/17? The three buttons on its screen are grayed out. Only [About] works. I think it might be replaced by Netgear Genie 8/19/2020 or otherwise not bei...
StanH
May 13, 2021Tutor
Update -- more information:
I suspect this is left from a previous router, not the current R7000. Date on exe: 7-29-2013, software v1.36, driver v1.83.35.
