StanH's avatar
StanH
Tutor
May 12, 2021
Can I remove NETGEAR USB Control Center?
Should I remove "NETGEAR USB Control Center" 11/21/17? The three buttons on its screen are grayed out. Only [About] works. I think it might be replaced by Netgear Genie 8/19/2020 or otherwise not bei...
