thebditch
Mar 01, 2022Aspirant
Can I use a Nighthawk 5G WiFi 6 Mobile as a failover by plugging into through my RAX200
Hi,
I current have a RAX200 router connected to a CMT2050V modem and Xfinity. If Xfinity fails I would like a alternate solution using T-Mobile 5G. I see that the Nighthawk AX4 4G LTE Modem can be used to access T-Mobile, so can I unplug the CMT2050V and connect the Nighthawk® AX4 4G LTE Modem somehow? Of is there a better modem router solution which allow for failover and is as good as the RAX200?
The M5 does have an ethernet port to contect it to the RAX.
A couple issues through.
1. the RAX doesn't support dual wan/failover. So you'd have to manually switch it in the settings to the M5 for internet whenever you needed to connect it up.
2. the M5 and the RAX both run by default in router mode. When wired together, it creates a double nat. You could either put the M5 in passthrough mode or you could put the RAX in access point mode.
the M5 does have a "data offloading" option.
It'd allow you to wire it into the RAX and the M5 would use the RAX for data. Then if the primary modem drops, you could just connect to the M5's wifi and use that.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
