khapunkap's avatar
khapunkap
Follower
Jun 28, 2022
Can not access NETGEAR router login
Hope you can help.
Specs - Modem: Arris DG3450 (also a router) Router: NETGEAR Nighthawk R7000 Firmware: unsure but definitely outdated since 2017 WiFi extender: NETGEAR Nighthawk EX7000 Internet provider: RCN
I am trying to access router login but cannot seem to do so. I just did a factory reset. Before the reset, I was able to log in but couldn’t update the firmware. After the reset, I can’t log in at all.
Here’s what I’ve tried so far:
  • Factory reset router
  • Cleared internet cache
  • Tried on mobile device and desktop computer
  • Unplugged wired connection and tried just wireless connection
  • Reset modem and router
  • Paused pop up blocker
  • Tried via routerlogin.com, the IP address, and the Nighthawk app to no avail
When I try to log in via desktop I get an error that my computer is not connected to the router network, even though it is. When I try to log in via Nighthawk app I get a bit further but it stops working once it checks for firmware. When I download the firmware file off the NETGEAR site manually it just downloads text files and nothing I can actually run or install.
Any help is much appreciated. Let me know if you need more info.
1 Reply
  • routerlogin only works when the router is the only one on the network. You have 2 routers (your Arris + the R7000). In that case, look up the IP Address of the R7000 assigned by the Arris and use it to login (eg, http://192.168.0.10)
