Boulda's avatar
Boulda
Tutor
May 31, 2017
Can not connect to other machines on network with R9000
I have just installed the R9000 last night. I am not having issues connecting to other PC / network shares. All the machines can get out to the internet. I can connect to them via remote desktop. ...
  • TheEther's avatar
    May 31, 2017
    When changing routers, Windows will often think that it has connected to a new network and will proactively treat it as a public network.  On Windows 10, you will have to change the setting to make the PC discoverable.
