kityowah
Sep 07, 2016Aspirant
Can not login to netgear R7000 router after factory reset
Can not login to netgear R7000 router after factory reset. All I get is connecting
and after 10 minute I hit cancel and it goes to Router Password Recovery. I put in serial # of router and the the continue button is greyed out!
I would like to change the password from the default for security reasons!
Is there a work around for this problem.
I can not believe Netgear has not corrected this problem before now. Not a very good selling point for Netgear Routers!!!!!!!!!!!!!!!!!!!!!
Re: Can not login to netgear R7000 router after factory reset
try the 30 30 30 reset
Good Luck with it!
The 30 30 30 reset....worked!!!!
Thanks for the suggestion!
- Retired_Member
Use defaults on router label after a factory default reset. Locate a manual too everything you need is in it.
