Sunshineqaf22
Mar 22, 2021Aspirant
Can see wifi and conect but no internet
So I Got The Modem WiFi Router Combo. I can See the WiFi and connect to It but It says no Internet. I have followed all the troubleshooting and unless I'm connecting a computer It isn't Allowing In...
Mar 22, 2021Guru - Experienced User
who's your isp?
did you get it activated through your isp?
do you have a screen snip of the modems cable connection page and event logs?
Do wired devices work?
Sunshineqaf22
You thru out a lot of rapid fire questions there. All the computers connected to wifi no problem only phone and Tv's will not connect. I followed all the suggestions for troublshooting and netgears suggestions but none work. It just will not allow anything other than computer to have internet access.
- plemansMar 22, 2021Guru - Experienced User
So computers connecting to wifi work fine?
Have you connected more than 1 computer to the wifi?
What error do the phones/tv give you when you're trying to connect?
Does the tv connect if you connect it with a ethernet cord?
