Sunshineqaf22
Mar 22, 2021Aspirant
Can see wifi and conect but no internet
So I Got The Modem WiFi Router Combo. I can See the WiFi and connect to It but It says no Internet. I have followed all the troubleshooting and unless I'm connecting a computer It isn't Allowing In...
Sean901
Mar 22, 2021Tutor
Similar issue here all weekend. Some devices connected fine, yet on others told there's no internet connection. Same system connects then gets thrown off internet even while other connected devices are fine. Power cycled all systems repeatedly, no change. Feels a lot like there's bugs in the firmware update that need to be addressed.
- plemansMar 22, 2021Guru - Experienced UserThe RBR50 is a different device from a C6300. Once a mesh system and the other is a modem/router combo device. I'd encourage you to start your own thread in the orbi forum
- Sean901Mar 22, 2021Tutor
Understood. Thanks for the tip. Already have a post over there and wasn't paying attention to which subforum / device folder this was in. Cheers.
