jpmd70
Mar 20, 2016Aspirant
Can the C7000 be mounted?
Hi, Can the C7000 be mounted? Does it have holes for screws so it can be attached inside a network box on the wall?
- Mar 21, 2016
I will say without a doubt you do not want to mount the C7000. In the product design phase it once had mounting holes on the casing, but the hardware inside runs too hot to safely mount the unit. It needs the venting all around it. If you were to mount it with one side against a wall air cannot flow properly. If you do somehow mount your C7000, I can basically guarantee you will overheat it and have a hardware failure, and could even start a fire.
