Mischa202
Jun 24, 2017Aspirant
Cannot Access Admin on R700
Am trying to install firmware update. I can access router wirelessly as well as ethernet cable, access to internet is no problem. accessing routerlogin.net and entering valid info does nothing, bla...
- Jun 24, 2017
Try IE or FF or Opera browsers to access the routers web page at 192.168.1.1..
What Mfr and model# ISP modem do you have the NG router connectecd too?
Jun 24, 2017Guru - Experienced User
Mischa202
Furrye38, thanks for the suggestion of using other browsers. And here is where it gets strange: I was using Firefox, tried Chrome and IE each from two different PCs. no luck. Tried it from Safari and it worked. Went back to laptop wired to router, logged in, was told I was already logged in on another computer, press yes to disconnect that one." That worked.
Now, in spite of the fact that I left a zero off the model number in the Subject line and before you suggest it, After the first 3 failures, ALL log in credentials were typed in one finger-one key at a time. ;)
After 10 years in IT, I despise technology.
Thanks for the quick reply and suggestion.
- FURRYe38Jun 24, 2017Guru - Experienced User
I hear ya, been in technology for 20...gets crazy sometimes.
Enjoy.
