RJRJ
Jan 02, 2018Aspirant
Cannot disable DHCP
I'm trying to disable the router's DHCP server following the instructions here on netgear kb and unfortunately the LAN menu is grayed out. The router is in WAP mode and I'm thinking that DHCP wasn't ...
- Jan 02, 2018
If you have not found it already, this will help with what you can and cannot do in AP mode:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
michaelkenward
Jan 02, 2018Guru - Experienced User
