avis123
Feb 19, 2019Tutor
Cannot figure out Service type and port number to block a computer
Hi,
I have a computer to which I have given a static ip address in my NETGEAR router. This is the device I would like to schedule computer downtime.
However for Service Blocking
I have the following three parameters that I need to fill:
Service Type, Port and IP.
I already know the value of IP. Now for Service Type and Port I am not sure what would be the parameters.For Service there is a dropdown that I need to choose from. However, for port how do I find the value corresponding to the fixed ip address? I would appreciate any help for resolution of this issue.
Thank you antidote and shadowports. I appreciate your help. Finally I have a solution!
> NETGEAR router. [...]A static address is configured on the device ("a computer") itself.
If you mean that you did something under "ADVANCED > Setup > LAN Setup :
Address Reservation" on the router, then you reserved a _dynamic_
address for your "a computer".> [...] Now for Service Type and Port I am not sure what would be the
> parameters. [...]Do you mean ADVANCED > Security > Block Services?
What, exactly, would you like to block? Something? Everything?
"Service Type"? If you want to block some particular, popular,
single service which appears in that list, then choose it. If you want
to block more/different services, then choose "User Defined", and
specify a (user-defined) name of your choice.> However, for port how do I find the value corresponding to the fixed
> ip address?You don't. Address and port (service) are two separate things.
Think of a street address and an apartment number in the building at
that address.> I would appreciate any help for resolution of this issue.
Making clear what you're trying to do would be a good way to start.
Define "computer downtime". If you want to block _all_ Internet
access, then you could define a service which includes all ports:
1:65535.avis123,
This is not a foolproof way of blocking a connected device from accessing the internet. We just want you to be aware of this.
Select > All, TCP/UDP, ports 1~65535.
- avis123Tutor
