Peter-Evans
Jan 18, 2017Aspirant
Cannot log in to my router Nighthawk R7000
Just buoght and trying to install a Nighthawk AC1900 Model R7000 Wifi & cable router. When I try to login to configure the router with www.routerlogin.net I get back the message "This page can't be ...
- Jan 19, 2017
Thanks for your reply MichaelKenWard.
Yes, assiduously. The instruction booklet is wrong on how to login to the router. I picked up from the web to not use 'www.routerlogin.net' but to go in directly via 'http://192.168.1.1/start.htm'. That worked.
I'm very critical of Netgear sending out incorrect information in the installation guide, therefore. It wasted almost day of precious time, can't imagine how many others have also been misled.
Thanks again.
michaelkenward
Jan 19, 2017Guru - Experienced User
Did you follow the order for turning things on specified in the Installation guide?
R7000 | Product | Support | NETGEAR
Peter-Evans
Jan 19, 2017Aspirant
Thanks again.
- michaelkenwardJan 19, 2017Guru - Experienced User
Peter-Evans wrote:Yes, assiduously. The instruction booklet is wrong on how to login to the router. I picked up from the web to not use 'www.routerlogin.net' but to go in directly via 'http://192.168.1.1/start.htm'. That worked.
Not wrong, but incomplete. It works for most people.
These are the common ways in:
http://www.routerlogin.com/
and
http://www.routerlogin.net
If they don't work, then the IP address might be an option. Here the usual suspects are:
http://192.168.0.1
or
http://192.168.1.1
The last of these is actually in the manual for the R7000, on page 20.
Even that is not complete. It depends on the topography of your network and what is in charge of various functions, which is why the order of doing things is important.
That's why there are so many messages around on the theme of "Cannot login to router".
You have cut to the chase quicker than most. (No need to resort to the "ipconfig" route.) The number of variables means that some people take much longer. Well done.
If you mark your own solution as Solved you can help people who turn up later with the same challenge.
