MattMatt
Jan 16, 2016Star
Cannot Reset Parental Filtering for Bose Soundtouch Speaker
Model R8000, Nighthawk X6, Firmware 1.0.3.4 (Genie tells me it's the latest version), just updated Genie software as well. I have parental controls enabled, blocking most "time-wasters", so to sp...
- Feb 05, 2016
No, Pandora is not blocked when it is set to None.
I solved the problem.
When I set it to Media Device, it gives no option to reset the level of parental controls. So I selected "Windows PC" and now it works. So despite the fact that it's just a speaker, I had to set it to "Windows PC" in order to take the filtering off. Weird, I guess.
MattMatt
Feb 05, 2016Star
JamesGL
Feb 08, 2016NETGEAR Employee Retired
Hi MattMatt,
Glad it works now. Your solution might be helpful to others.
