Huike
Oct 27, 2016Guide
Can't access the Router Login page (again)
Background: I am a Microsoft and Cisco certified network engineer for many years and configured thousands of modems/routers/switches etc etc. Bought a new X6 R8000 router and did a factory reset ...
- Nov 05, 2016
Ok finally got to the login page by connecting to the 5GHz band. Put in 192.168.1.1 and the router asked login name and password. Used the default login info to log in and immediately flashed DD-WRT and all good now. Still strongly suggest Netgear remove the restrictions for login from Ethernet which is unnecessary.
Huike
Nov 05, 2016Guide
IrvSp
Nov 05, 2016Master
Huike wrote:Still strongly suggest Netgear remove the restrictions for login from Ethernet which is unnecessary.
I do not recall that restriction at all? You might be mistaken though. The only 'restriction' is that you SHOULD NOT flash the router from a wireless device, only a wired one. Reason is the wireless device could drop before the flash is completed or fully loaded.
