Aymeric_Moreau's avatar
Jul 30, 2018
Can't assign printer an ip address
I'm trying to configure a Canon TS8120 printer. I don't have an Ethernet port so I can only connect wirelessly. In attached devices, Nighthawk sees the printer, and sees the printer's MAC a...
  • Aymeric_Moreau's avatar
    Jul 30, 2018
    I solved the issue.
    to address your question : there was no conflict.
    to solve the issue : I have reset the router to factory settings, then reset the WiFi Password, and all the sudden, it gave the printer an IPAddress.
    So all is good.
    Thx for your help
