Japio's avatar
Japio
Can't connect to readyshare WIN10
Hi,
I have a R7000 Nighthawk router (latest firmware) and try to connect some USB storage to it.
I have tried several. Connecting to the router goes ok, the router finds the drive and it is possible to make some changes in the http/ftp setttings as well as the storage folder. So far so good.
But, in windows network it finds the netgear router as a networkthing and also as a computer. But not as storage. When I try to log into it as computer it needs admin as user but the password is disapproved. I typed it right, i am sure off that.
I have tried to use all kinds of fixes I could find on the internet regarding my laptop and WIN10, nothing worked so far.
So. perhaps you can help me out ?
  • michaelkenward's avatar
    michaelkenward
    How is it formatted?
    What are the USB drive requirements for ReadySHARE on my NETGEAR router? | Answer | NETGEAR Support
    What sort of USB storage? Is it anywhere on this list?
    ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
    That isn't up to date or complete, but it offers some guidance.
    Windows does not like it if you use old and "unsafe" network security features.
    Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
    • Japio's avatar
      Japio
      It is FAT formatted but I tried NTFS as well.
      I tried several different storage devices. USB stick, USB SSD, USB HDD.
      They are without login protection.
      None of them worked.
      For SMBv1, something strange happened.
      I enabled it but wanted to check if it is still enabled but now it is no longer in the features list. I don't know how to get it back.
      I tried a lot of other changes in Windows, for instance in lanmanserver in regedit.
      Nothing worked for now.
        michaelkenward
        Microsoft loves moving things around.
        Where are you looking?
        • Start
        • Features
        • Turn Windows features on or off
