firestorm31's avatar
firestorm31
cant log in to nighthawk R7000P router
the router works ok with the computer on the internet (it is a wired connect) but I cannot log in to the router nor can the epson XP-830 wifi printer communicate with it.  i was troubleshooting on why the printer won't connect. the router seems to be the culprit.
http://192.168.1.1/ or http://www.routerlogin.net/ does not work.
do I need to do a reset?
