Firecapt's avatar
Firecapt
Can't log into router after recent firmware upgrade
Just upgraded the firmware on my R7000 from 1.0.4.30_1.1.67 to 1.0.4.48_1.1.79.  After the upgrade I have been unable to access the router either using a browser or through Netgear Genie.  The router seems to be working normally since I have access to both wired and wireless internet.
Any suggestions?
  • I just got my router setup again and I decided to use the DHCP reservation again as well for my machines, i do a lot of network file exchanges for files and its just been easier to assign everything through the router, just takes a while for 50ish devices thats including friends and family.
    Anyway, thank you everyone, have a Merry Christmas and a Happy New Year.
  • Have you tried logging in through your browser using the IP address directly?   e.g. 192.168.1.1
      • PEHowland's avatar
        PEHowland
        Apprentice
        I assume you get a "Page not Found" (404) error?  If so, and given that the router is working otherwise, it sounds like the internal web server used to provide the web pages is not working.  I can't think of any solution beyond the normal reboot and, if that fails, hard reset to wipe all the parameters and start configuration from scratch.  Of course, there's a risk with the latter that you wipe the parameters and then still can't access the settings and then you're worse off than you are now!
