shibakid's avatar
shibakid
Follower
Dec 23, 2016
Can't register Archer C7 (AC 1750 dual band wireless router) won't accept serial n°
Hi all, Just installed the Archer C7 router. Works well. Now, I want to register this router on the Netgear site, but the system doesn't accept the serial number (13 digits)   Also, the support s...
  • TC_in_Montana's avatar
    Dec 23, 2016
    I believe the Archer C7 is a TP-LINK  product.   Not a NETGEAR product.
    You would need to go to TP-LINK's website to register that device.
