dachelpo
Nov 10, 2016Aspirant
Can't Register R8500
I posted several days ago but have received no appropriate responses and now I do not see my post (deleted? -why?)
When I tried to register my product I received the statement that it was alrea...
Nov 10, 2016Guru - Experienced User
This is in the ReadyNAS area, so you posted it in the wrong place.
I will move to the Nighthawk router area. Hopefully someone from Netgear support will see this and get back to you.
You might try one more time in the meantime though, and triple-check the serial number you enter.
dachelpo
I have triple checked that I entered the correct serial number. Thanks for the help in getting it posted in the proper area.
