Amorpheus's avatar
Amorpheus
Can't rollback to the most recent factory firmware after rolling back from DD-WRT on Netgear R7000
I'm trying to update the firmware on my old Netgear R7000. I initially tried flashing it with the latest DD-WRT beta release (2024), but I wasn't satisfied with it. I decided to revert to the factory firmware, starting with the initial release, R7000-V1.0.3.24_1.1.20.chk.
After successfully booting and configuring the initial firmware, I attempted to update it through the router's GUI. However, each time I clicked "Check for Update," it seemed unable to connect to the update server. I suspected that the factory firmware might be too old and the update link may have changed.
Consequently, I flashed the most recent factory firmware directly. However, after flashing and restarting, I could no longer access the GUI, neither through routerlogin.net nor the IP address 198.162.1.1. Furthermore, my computer's Network Adapters no longer recognized the router, whereas with the initial firmware, it was recognized as "Nighthawk5G."
I reverted to the initial factory firmware again, restoring normal functionality. I then tried installing firmware versions one by one, gradually working my way up. The last version that worked without issues was R7000-V1.0.7.10.1.2.3, but it's still quite old.
I even considered that firmware versions might differ across regions since I originally purchased my R7000 in China. However, flashing the latest firmware from Netgear China resulted in the same problem: the router was either detected as an "Unidentified Network" or got stuck in a "Connected-Disconnected Cable" loop.
I've been performing all flashes using NMRPFLASH.
What steps can I take to successfully install the latest firmware on my router?
Thank you
  • FURRYe38's avatar
    You may need to update stock FW from initial to something in the middle of the versions that are available first before going to most current version of FW.
    Any 3rd party FW support information will need to be asked over on there support forums.
    • Amorpheus's avatar
      Amorpheus
      Thank you for your reply and time. Maybe I haven't expressed myself clearly, but that is exactly what I did.
      I was on DD-WRT latest Beta branch for R7000, then rolled back to initial release of stock firmware and then gradually flahsed as follows:
      1.0.3.24
      1.0.3.56
      1.0.3.60
      1.0.3.68
      1.0.3.80
      1.0.4.18
      1.0.4.28
      1.0.4.30
      1.0.5.64
      1.0.5.70
      (Anything more recent from these point and R7000 is unresponsive, Unindentified Network/Connected-Disconnected-Loop/No reaction on 8 or 30 second hard reset)
      1.0.7.2
      Amorpheus
      Also on DD-WRT support forums one of the folks told me I should ask here 🤣
