Snu
Mar 21, 2017Aspirant
cant see content from my NAS (R7800)
Hello there. Ive got a problem with my new router (Netgear R7800). Fist of all, on the previous router (Asus) everything worked correctly. All that has changed is the router itself. Configuratio...
- Mar 23, 2017
A good old fashioned factory reset with a complete shutdown and reboot of your devices could help.
regards.
schumaku
Mar 23, 2017Guru - Experienced User
Snu wrote:Problem:
The devices do not read content from the NAS. To the server is connected, the folder structure and the files themselves are visible.
Interestingly, you talk about folder structure and files ... however, I doubt all your clients listed have (at least not by default) access to folders and files using a protocol like SMB (CIFS). I suspect you access the media on the Synology using DLNA (UPnP AV) as explained in How to enjoy multimedia contents stored on Synology NAS with DLNA/UPnP-compliant DMAs
Before investigating more: Double and tripple chck all your device network interfaces ae set-up into the exact same TCP/IP subnetwork, with the very same subnet mask.
If this still does not help, and based on the information you mentioned that the earlier firmware on the router was fine ... reads like a (fat) bug to me. Have no R7800 at hand, so can't test. Somehow hard to imagine the SOAP HTTP communication to list the content (in whatever structure) does work, but the media ccess itself should fail. Do you have ie. a current Windows 10 systme on the same (W)LAN? You might try to discover the Syno DLNA from Windows Explorer (with the Network Discovery Services enabled, and the UPnP User Interface protocl loaded on the network interface) or just run the Windows Media Player and try to access it.
Note: In DLNA, there are no DMA - much more are DMR (Digital Media Renderer) and DMC (Digital Media Controller) typically indeed comind into one box, but you could use an external DMC ie. on a mobile App to select media from the DMS (Digital Media Server - your NAS).
-Kurt
Snu
Mar 23, 2017Aspirant
So, it was long and difficult, but finally figured out. I made a factory reset of all devices. Now everything works. All thanks for the advice!
Question for consideration: why when installing the router (with the rest of the equipment unchanged), there was such a failure?
- aalexandrebetaMar 24, 2017Master
You are welcome.
""Question for consideration: why when installing the router (with the rest of the equipment unchanged), there was such a failure?""
The answer I can give you is that your previous equipment asigned IP address to your other gears, so when you switche from oldie to the R7800 the router tried to designate ip of its own on already registred IPs. So it's a messy situation.
