Snu
Mar 21, 2017Aspirant
cant see content from my NAS (R7800)
Hello there. Ive got a problem with my new router (Netgear R7800). Fist of all, on the previous router (Asus) everything worked correctly. All that has changed is the router itself. Configuratio...
- Mar 23, 2017
A good old fashioned factory reset with a complete shutdown and reboot of your devices could help.
regards.
Snu
Mar 23, 2017Aspirant
So, it was long and difficult, but finally figured out. I made a factory reset of all devices. Now everything works. All thanks for the advice!
Question for consideration: why when installing the router (with the rest of the equipment unchanged), there was such a failure?
aalexandrebeta
Mar 24, 2017Master
You are welcome.
""Question for consideration: why when installing the router (with the rest of the equipment unchanged), there was such a failure?""
The answer I can give you is that your previous equipment asigned IP address to your other gears, so when you switche from oldie to the R7800 the router tried to designate ip of its own on already registred IPs. So it's a messy situation.
