pistos's avatar
pistos
Follower
Jul 25, 2017
Can't select folder in ReadyCloud App
I've attached a Seagate 8T drive to my R8000 router and turned on ReadyCloud. On a remote computer, running Windows 10, I downloaded the ReadCloud Desktop client and signed in. I can see my router and the top folder, but I can't select the folder. I am able to access the folders from the ReadyCloud web site. Any ideas what is wrong?
  • Hi pistos,
    If you have antivirus, try to exempt the ReadyCloud App.
    Try to install it as well to a different computer.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi pistos,
    • JamesGL's avatar
      JamesGL
      Hi pistos,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
