hxquero's avatar
hxquero
CAX80 blocking Samsung TV Plus
And the second I connect the TV to my T-Mobile hotspot - Samsung TV Plus works as it should!! NETGEAR needs to correct this issue ASAP.
    • hxquero's avatar
      hxquero
      I hope not...NETGEAR really needs to standby their products and give consumers what they think they're paying for.  It can't be that complicated - Samsung TV Plus works great on my corny T-Mobile Hotspot LOL!
  • Well, it's been a whole month and no solution.  I'm at my wits end...I will NEVER purchase another NETGEAR product and I'm headed to Best Buy to purchase a Motorola!
    • FURRYe38's avatar
      Please post about this over in the cable modem forum:
      https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
      I believe NG put forth a new FW update a bit ago regarding this. Something to try if you haven't already.
      "@tamanaco wrote:
      The issue with Samsung TV Plus was solved after I updated my CAX80 router firmware to version 2.1.2.6 today. WiFi calling appears to be working after this update as well" <Seems to be working for this user.
      Helps to post in the right forum though.
      Thank you.
      • hxquero's avatar
        hxquero
        I did update the firmware - still didn't work.  Thanks.
