Copwriter
Aug 05, 2017Tutor
Change connected device name on R7900P
The devices connected wirelessly to my R7900P router are listed mostly by MAC address alone. The device name is blank in most cases. How can I edit this field in the routerlogin.net screen so I can s...
- Jan 21, 2018
The simple name field appeared to be editable when QoS was enabled. In fact, many of the columns of data in the attached devices screen change (for unknown, and non-understandable reasons) when you enable QoS. It's really irritating and limiting. Also, the name field isn't stored with permanence in a database...it can change across reboots-which is really strange. You'd think that the device would keep a database with MAC addys in non-volatile memory, but it doesn't appear to-which is disappointing, tbh.
JamesGL
Aug 09, 2017NETGEAR Employee Retired
Hi Copwriter,
Update the firmware to the latest one.
https://kb.netgear.com/000045278/R7900P-Firmware-Version-1-1-3-2
- JamesGLAug 13, 2017NETGEAR Employee Retired
Hi Copwriter,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- CopwriterAug 16, 2017Tutor
I downloaded and installed the firmware update, but I still don't see any setting to provide device names to my connected devices. I see the MAC addresses and IPs, but the device names are mostly blank.
