rochrunner
Mar 21, 2021Tutor
Change from AP Mode to Router Mode
I've been using my R7000P for a while in AP mode, connected to a router supplied by my service provider. However, if I "cut the cable" as planned, I'll be connecting directly to a normal cable modem ...
rochrunner
Mar 21, 2021Tutor
Yeah, as pointed out, the problem with the factoy reset would be the other settings that I'd have to redo, although I don't think there are that many (SSIDs and passwords, etc.).
Mar 21, 2021Guru - Experienced User
You can always try it with just switching it out of access point mode.
If it has issues, then try the factory reset
