rochrunner
Mar 21, 2021Tutor
Change from AP Mode to Router Mode
I've been using my R7000P for a while in AP mode, connected to a router supplied by my service provider. However, if I "cut the cable" as planned, I'll be connecting directly to a normal cable modem ...
antinode
Mar 21, 2021Guru
> When you set the r7000P in access point mode, it got the ip address
> from the router its connected to.
It did, if you chose "Get dynamically from existing router." If,
instead, you chose "Use fixed IP Address (not recommended).", then you
specified a static address (and other parameters) yourself. Presumably,
you'd remember doing that if you'd done it.
DanG_NOLA
May 16, 2021Aspirant
Currently both are AP. I switched the R8000 back to router but when I connect to it, it apparently issues an illegal ip or none at all. The default IP won't talk to it. The two netlogin addresses don't work either. None of 192.168.1.1, .1.254, .0.1, nor .0.254 work. I rebooted it 3 or 4 times. No help. I hit the reset button, it returns to AP mode with all my settings intact. After I deselect, AP mode and restart, hooked up to Ethernet port 2, what else do I need? My laptop is set to get IP number from router.
- antinodeMay 16, 2021Guru
> Currently both are AP. [...]
One: Start your own thread for you own problem with your own details.
Two: The non-psychics in your audience can't see what you're doing,
or what happens when you do it.Both what? I'd expect having one router (operating as a router) to
be a better plan than having none. Is some kind of modem involved?> [...] I switched the R8000 back to router but when I connect to it, it
> apparently issues an illegal ip or none at all. [...]When you connect what, exactly, to what, exactly? "apparently"?
None of this is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] The default IP won't talk to it. [...]Huh? Do you mean some "IP" _address_? An IP address doesn't talk to
anything. See "None of this is a useful problem description [...]",
above.> [...] don't work [...]
See "None of this is a useful problem description [...]", above.
> [...] I hit the reset button, [...]
For how long? With what resulting LED activity? Did you read in the
User Manual how to do that?Visit http://netgear.com/support , put in your model number(s), and
look for Documentation. Get the User Manual (at least). Read. Look
for "Reset".> [...] hooked up to Ethernet port 2, [...]
You "hooked up" _what_ "to Ethernet port 2"?
