tommie
Dec 03, 2020Aspirant
Change wifi password for ex7000
How does one change the wifi password? I have changed the password for the wifi router and must now them for the extenders. This is an EX7000. Thank you
You can log into it using the ip address of it and change it through its settings.
https://kb.netgear.com/26074/How-to-change-the-SSID-password-and-wireless-security-of-your-EX7000
- tommieAspirant
Thank you I will give that a try.
