joeperez's avatar
joeperez
Changed network passwords, now PC won't connect!!!
I correctly followed the steps to change my router's network password from the default that came with the router. From within the Genie webpage I can confirm this (there are three different "networks," the regular PC connection, a 5G network that I assume is for my iPhone, and a "60G" that I have no clue about. I changed the regular and 5G network passwords to the same new password and left the 60 alone since I have no clue what it would be for.
I can connect with my iPhone to the 5G network using the new password, but my PC only two feet away from where I sit with my iPhone will not connect. I can only get a connection throught the built-in router of the cable modem. Before I changed passwords I had no trouble connecting with the "factory" password the very first time I connected. Now, when I select the NETGEAR91 network (changed only the passwords, not the network names) I don't even see any options to enter the updated password (using windows 10 and clicking on the little "wifi umbrella" in the lower right.
I'm getting a "Can't Connect To This Network" when I manually click the Connect button.
Any help appreciated.
  • Yes, thank you. In Win10 I have the "Connect Automatically" box checked for the Nighthawk X10 (NETGEAR91) that displays in the list of available networks. So I get a connection practically as soon as I power up the PC.
  • UPDATE!
    I stumbled across a very helpful article in the support section that clued me in to the fact that the PC is still using the old passwords to connect, and that I had to got into my Network Settings and tell the setting to "Forget" the NETGEAR91 network, which I did. Then, since the network is in the area and available to be joined (it *is* upstairs) when I selected "Connect" this time, it wanted a password, and I gave it the new one, which worked just fine.
      • joeperez's avatar
        joeperez
