DianaNashif
Oct 19, 2017Aspirant
Changed router password not can't login
Having trouble with my router. Did login using the default login. Once in there was a firmware update that I processed. Had to then log back in no problem. Next I changed the router password and d...
- Oct 20, 2017
You can get back to the default password by doing a factory reset on your device.
There is a manual for the R8000 somewhere at the end of this link:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
michaelkenward
Oct 20, 2017Guru - Experienced User
- DianaNashifOct 20, 2017Aspirant
Thank you!
Tried that and still couldn't get in. Gave up and bought a new NightHawk X6S. Getting better signal now so I think the old one was on it's way out.
Cheers,
Diana
