DianaNashif's avatar
DianaNashif
Changed router password not can't login
Having trouble with my router.  Did login using the default login. Once in there was a firmware update that I processed.  Had to then log back in no problem.  Next I changed the router password and d...
  • michaelkenward's avatar
    Oct 20, 2017
    You can get back to the default password by doing a factory reset on your device.
    There is a manual for the R8000 somewhere at the end of this link:
    >>>>> R8000 | Product | Support | NETGEAR <<<<<
