Kiddfam
Apr 20, 2022Initiate
Changed Router Wifi Password and now Iphones say "no internet connection" on 5G network
Our home webcam was hacked the other night and it was connected directly to our Netgear router so yesterday we changed the Wifi passwords for the 2G and 5G Networks via the Nighthawk app and checked it via the routerlogin.net. Unfortunately now we can connect our Iphones to the 5G network however it then says "no internet connected" and we can't access anything.
2G works fine but 5G is a no go.
Anyone have any ideas?
did you try clearing the network settings on the iphone?
Also, are you using any parental controls/armor?
Are you using the "random mac/ip" feature on the device? try disabling it
