up4it1023
Dec 01, 2023Aspirant
check Firmware Error
I've never downloaded a firmware update to my R7000 router. When I purchased it, the big thing was Genie. Now everything is done through the Nighthawk App. My current firmware is v1.0.8.34. When ...
Dec 01, 2023Guru - Experienced User
Most likely the system won't update since it's kind far behind so ya, you'll need to manually update:
Does your PC have a ethernet port? Can connect the ethernet port to the back of the router then connect to the routers web page to manually update using a web browser.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
They make inexpensive USB to ethernet adapters as well if your PC doesn't have a Ethernet port.
