GeekGirrl
Sep 08, 2016Tutor
Chromecast still not working.
Anyone have success with their Nighthawk and Chromecast yet? I still cant even see chromecast on my pc steadily. I've done many tweaks to the router per this community and google with no luck yet. I...
- Sep 09, 2016
I guess I fixed the issue. Only one pc was having the issue so I just had to update chrome on that pc. Simply fix that is not on any other post or even in the suggested fixes at chromecast. I guess I always expect chrome to be up to date but it wasnt. My bad. Keeping the router for now as it rocks eventhough netgear support is horrible.
GeekGirrl
Sep 08, 2016Tutor
Update: I just talked with Netgear tech support and they will not assist you in setting up any device that nolonger works with your new netgear router. So I'm taking my netgear router back and buying an Asus or Linksys router. Maybe I'll have better luck with their tech support. I would advice anyone with chromecast to never buy a netgear router. Too many issues. Just google it and you will see. Good luck :)
