patentlymn's avatar
patentlymn
CM1200 connected to AC1750 r6400 no internet. BUT computer direct connect to CM1200 gets internet
I am using a nighthawk AC1750 r6400v2 that was working yesterday when acting as a wirless access port, I think. My son had configured it.  I used the wifi to watch youtube etc for months.  I just replaced the old Arris xfinity cable modem with CM1200. It works fine. I reset both to factory settings. When I connect the CM1200 port 1 to PC directly I get internet. No problem. When I connect CM1200 port 1 to r6400 WAN and cycle power on both I cannot get internet. I used the same short ethernet cable.
I connect via wifi I get the message "No internet, secured."
I tried the nighthawk app and connected to one wifi channel with the CM1200 connected to the r6400 WAM and got the message
"ready to connect when network quality improves." ????
The app went no further.
Network speed is 130 Mbps. It says
  • If you'd had it setup in access point mode prior, factory reset the R6400 and then reinstall it in standard router mode.
    to factory reset, push and hold reset for 7-15 seconds while its powered on.
    install guides for the R6400 can be found here:
    R6400 | WiFi Router | NETGEAR Support
    also, the CM1200 might have 4x ports but its a modem only device. Only 1 device can be connected to it unless you pay for a business class line or are one of the lucky few that support more (most don't)
  • plemans's avatar
    • patentlymn's avatar
      patentlymn
      I have done a factory reset on both devices.I only have one cable connected to the CM1200, at port 1. It is either from the PC as right now or to the CM1200 WAN when trying to get it to work. Also, I I tried to use port 1 on the r6400 to the PC ethernet port but it connected with no internet. So wired or wireless, no internet through the router.
      I looked at the user guide and will look at the links you provided. I really appreciate it.
      If it matters, I am using a freshly reinstalled windows 10 on a refurbished dell latitude e6440.
      I will do another factory reset on the r6400 and review the manuals.
      Thanks
      • michaelkenward's avatar
        michaelkenward
        Sounds like it might be a good idea to take the R6400 through its setup process.
        You connect the modem to the Internet port on the router.
        Reset both devices and follow the instructions as specified. The order is important.
