Dbarber92
Sep 14, 2021Follower
CM500>r6700v3 can’t connect
Hello! I am trying to connect with xfinity using netgear modem (CM500) and router (r6700v3, firmware V1.0.4.106_10.0.80). Xfinity says the modem is connected and working fine, and I can boot up the ro...
Sep 14, 2021Guru - Experienced User
Power OFF both modem and router for 1 minute then back ON with the modem first then router.
Swap LAN cables between the modem and router. Be sure to use good quality LAN cables. CAT6 is recommended.
You can test your PC directly connected to the modem as well to be sure the modem is working. Power OFF, connect PC, power ON modem...check internet services after modem is ready.
