mikeerwin
Feb 17, 2016Aspirant
Comcast Extreme internet still not up to speed with Nighthawk AC1900 R7000 - ISP issue
Hi Guys I have Comcast as a ISP. With there Extrememe 150MBPS internet. I decided to get away from there Modem/router combo Because I was pulling only about 45Mbps hardwired and about 35mbps wifi. So...
- Retired_MemberFeb 17, 2016
So after I'm guessing you spent $250 you're worse off than when you started. So is your new modem Dociss 3.1 ready? If not oh well when they upgrade in the very near future your modem may not take advantage of 3.1 which addresses BUFFER BLOAT.
Hey not trying to burst your bubble but, a lot BS is being sold without any back up to support it.
Ok, what to do now. Contact comcast for the slow speed tell them you had slow speed before buying your own modem. Hopefully they can resolve it. If not have them bring their modem out and prove theirs will deliver what you're paying for.
The r7000 does have some benefits one is the 5g AC option but you need AC clients to take advantage of it. My back round is in CATV, VOIP and HIGH SPEED DATA and I was involved in the Chicago Region with some of the very first build outs in the Chicago Suburbs going back to 1989. If you need anything else just ask.
PrimeNumber
Feb 18, 2016Guide
Go into the advanced setup for the R7000. Go to the QoS section and run the speed test function from there. Your router will go out and test your connection speed and set itself up appropriately. If you have never done this, or not done it since upgrading your internet service, your router will not use the extra bandwidth you are paying for. The router will not do this automatically, it must be done manually.
Retired_Member
Feb 18, 2016
You may be a bit confused about this. This would ONLY be true if QOS is enabled. The problem HERE is he cannot get 150 out of the modem, before even connecting the r7000 to the modem. Nothing in the r7000 will solve this problem.
