popowell1-'s avatar
popowell1-
Comcast WiFi extender. Will they work with Netgear router
Comcast WiFi extender. Will they work with Netgear router. I have consist as my provider. Recently replaced a Comcast router with a netgear and I can’t see if the extenders are worth.
  • > Comcast WiFi extender. [...]
       How much do you expect anyone here to know about your (unspecified)
    "Comcast WiFi extender"?  Has it a maker and model number?  Did Comcast
    provide any information on its capabilities, or instructions for its
    use?
    > [...] Will they work with Netgear router. [...]
       Ask Comcast?  Have you tried anything?  What happened?  Why wouldn't
    they?
    > [...] Recently replaced a Comcast router [...]
       Not a very detailed description of that device, either. Did your
    (unspecified) "Comcast WiFi extender" work with your (unspecified) "a
    Comcast router"?
    • popowell1-'s avatar
      popowell1-
      I didn’t ask for a SmartAss answer either. Yes, No or how about not reply dip**bleep**.
      • antinode's avatar
        antinode
        Guru
        > I didn't ask for a SmartAss answer either. [...]
           As we said when _I_ was a child: Better a smart answer than dumb
        question.
        > [...] Yes, No [...]
           Based on what information, exactly, would you like that answer to be
        based?  Your absent replies to requests for even the most basic
        information?  Good luck with that.
