Retired_Member
Sep 04, 2021COME ON NETGEAR WAKE UP AND FIX THE BROKEN DNS YOU CAUSED
WAKE UP NETGEAR. FIX THE DNS ISSUE YOU CAUSED WITH THE FLAWED FIRMWARE UPDATE. PLEASE REALISE WE BUY ROUTERS TO USE THE INTERNET, SO IF THEY DONT WORK ALTERNATIVE VENDORS WILL BE FOUND.
This is the community support forum. Where members of the public help out. We're not netgear.
There is the occassional mod on here but its rare and far between.
- Retired_Member
Yes I fully understand that this is not an official Netgear forum. But how else can one get Netgear do fix their products so they work as they are supposed to. Netgear so called support is non-existent, having tried to get a response from someone there.
Did you try downgrading the firmware? Theres been more than 1 model effected by the dns issue on the curent firmware.
