dreyfus
Aug 08, 2017Tutor
Compatability - Plex Media Server on Nighthawk R9000 and LG TV
I am thinking of upgrading from Nighthawk X8 to X10. The main reason is the embedded Plex Media Server software and the powerful CPU. I have a 2013 LG Smart TV which is not compatible with the PMS a...
- AnonymousAug 09, 2017
dreyfus wrote:Is this what you mean - http://www.ebay.com.au/itm/Q-BOX-Android-6-0-TV-BOX-KODI-17-1-Media-Player-Quad-Core-2-16G-4K-HDMI-Keyboard/132217785886
This is the one we have, its 8 core and rappid, I believe it is alreadyy rooded, if not., it was easy to do.
Regards
Anonymous
Aug 08, 2017Have you tried Xplay, we use that on our LG TV, it works and looks like PMS, you can try it free to check.
X10 aren't all that much better than other simular routers , Asus is better though, the X10 also has a lot of problems and feels like a Beta testing router.
Regards
- dreyfusAug 08, 2017Tutor
@Bartman007 wrote:Have you tried Xplay, we use that on our LG TV, it works and looks like PMS, you can try it free to check.
Regards
Thanks for your reply - My LG TV is 2013 model, pre WebOS apparently. When I go to the app store I am told Plex apps aren't avaiable for my model becuse it can't run WebOS. Built-in obsolescence if you ask me. Any other suggestions? Good to know about the X10 though.
- AnonymousAug 08, 2017
Android TV box, again, we have one on 1st edition sharp Aquos 1080p LCD TV, the box runs kodi and you can get PMS on Android, a good 8 core one will set you back (UK Pound, sorry) £50, it will also make your TV into a great media system .
Regards
- dreyfusAug 09, 2017Tutor
I will look into this solution. It sounds similar to the Roku my ISP provided, although I have discovered I would have to crack it to developer mode to download any more apps to it.
