Nukeman10's avatar
Nukeman10
Compatibility speed issues between Nighthawk X8 R8300 and Galaxy S9 plus
I just bought a Galaxy S9 Plus and have found that when it connect to my R8300 it will only connect a 54 gigabit per second on the 5G. I also own an R 8500 and it connects just fine over 500 gigabits second. With all the testing I've done I have found that there seems to be a compatibility problem between the Nighthawk X8  R8300 model and my brand new Galaxy S9 Plus. Has anybody else connected these two specific models together. I have other phones and other devices that connect at a much faster rate than this specific phone the Galaxy S9 Plus. Please let me know if you've run into this exact problem. It's only connecting at the rate of a 2.4 speed, basically the old G speed.
  • After performing a full reset and reloading all configuration problem sovled.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Nukeman10,
    What is the firmware version of the router?
    What is the channel of 5Ghz on R8300 and R8500?
    • Nukeman10's avatar
      Nukeman10
      Both Routers, R8300 and R8500 are at 1.0.2.116. The channels of the R8300 I've tried several. But currently the 2 5GHz are at 36 and 2nd one at 149. But again, tried them at others. It's odd, I'm a computer eng. and this really looks like a compatibility issue. Can you help answer my concern about the chipset differences between both models.?
      I always move my routers up to latest. Can you post an old one for me to try?
      Neil
        Nukeman10
        I have to say I am very disappointed. I own 3 Netgear hight end routers in my house, 2 of which are Nighthawk X8 - R8300 and X8- R8500. For the amount of money I spent on these I should not have to feel luck that I even get support. I paind over $700 just for these 2 and find it crazy that the new Samsung S9+ phone I just upgraded to only connects and 54Gb speed. Only the R8300 has this issue. And it's just with the Samsung S9 models. I have a LG V20 and it works fine. I am about to change router companies if this doesn't get addressed and fast. BTW, I Work for a large SSD manufacture and this would ben handled much better by my support teams. I hope you see this and will help me. Neil
