lebloom1801's avatar
lebloom1801
Compromised AC1750
I’ve got an AC1750 and have been compromised. Will a new router help me here and just what model in the $100 range is actually safe? Or am I gonna have to go much higher?
  • antinode's avatar
    antinode
    Dec 04, 2020
    > [...] this thing hasn't updated or has any updates that I've found for
    > months. [...]
       What is its current firmware version?
    > [...] What I want to know if this router can be the cause and someone
    > can hack into my accounts because this routers not safe?
       I suppose that it's possible, but I'd probably worry (much) more
    about your (unspecified) "my computer", and the ways that you use it,
    than about any of your networking equipment.
  • > I've got an AC1750 [...]
       "AC1750" is a speed, not a model number.  Look for "Model" on the
    product label.   Firmware version?  Connected to what?
    > [...] and have been compromised. [...]
       "compromised" how, exactly?  Have you any evidence that your
    (unspecified) router was to blame in some way for whatever (undisclosed)
    problem which you believe that you're experiencing?
    > [...] Will a new router help me here [...]
       That might depend on which kind of help you need.  Which, so far, is
    far from obvious.
    • lebloom1801's avatar
      lebloom1801
      I've got the R6400, sorry I thought AC stood for the for model,  not a expert here. But, this thing hasn't updated or has any updates that I've found for months.  By me saying I've been Comprimised, I mean my bank accounts has been dipped into.   I use my computer for buying things online.  What I want to know if this router can be the cause and someone can hack into my accounts because this routers not safe?
      • antinode's avatar
        antinode
        Guru
        > months. [...]
