dchemphill1
May 18, 2018Aspirant
Computer connects to router but no Internet connection
I am not sure if I have the exact model of the nighthawk router, but anyway here is the issue. If we connect directly (wired) to the router we can get on the internet, if we try wifi on the tv, cell phone, computer etc.... we can get connected to wifi but no data flows via wifi. We had some power outages and the internet company came out and said the modem was bad, hooked a new modem up and it worked fine, but same issue with the router....is it possible the wifi part of the router got fried or is there some setting that I can change to have data flow via wifi???
- Got it working. The reset and start from scratch along with an update did the trick.
Thanks All
- myerswMaster
Getting to the Internet via a wired connection to the router says the modem and router are basiclly ok. I am sure you have power cycled the router with no change. There is a possibilty that with the power issue you had the configuration in the router may have gotten corrupted. I would suggest a reset of the router and a reconfiguration not using a backup.
- dchemphill1Aspirant
So that means hardwire into router and set up like it is new out fo the box?
> I am not sure if I have the exact model of the nighthawk router, [...]
Look at the product label on the router?
> [...] we can get connected to wifi but no data flows via wifi. [...]
How, exactly, did you determine this? What, exactly, did you do?
What, exactly, happened when you did it?
> [...] is it possible the wifi part of the router got fried or is there
Yes.
> [...] reset [...]
> the box?
It means reset the settings, and configure it as if it were new.
This should be possible with a wired or wireless connection between the
computer and the router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual, and look for something like
"Factory Settings". Then the section(s) on router configuration.
 - William10aMaster
You mean you can connect a lan cable from the router not the modem correct and have the internet ?
You have done reset of the router and reset it up and the prolem is still there correct ?
If a firmware problem have you tried to reflash the the firmware on the router ?
Possible something was damaged in the wifi but you said the wifi transmitting with no internet content so part of the wifi circuits have to be working.
Would make sure every thing else was working correct before I would say the wifi was circuits were damage
Did you reboot the network in order after the modem replacement, modem first let fully boot, router next let fully boot and lastly let the your devices boot on the network ?
- dchemphill1AspirantGot it working. The reset and start from scratch along with an update did the trick.
Thanks All
