Walthart
Aug 21, 2015Aspirant
Config import R7000 to R7500
Can I export my R7000 config and import it on my R7500
- Aug 21, 2015
Qualcomm 7500 - Broadcom 7000. I would say no. Best to copy / paste your config, or do screen grabs of your config. Or, try it!
slompochomp
Aug 21, 2015Guide
Sounds like a job for trial and error. You can try and the worst is it does not work and you will end up doing what you would if we told you No and manually input all the settings from the 7000 to the 7500. It’s that or call Netgear support, but odds are they do not know and tell you not do it. The worst that can happen is it does not work and you end up having to do a hard reset/factory reset to default settings.
